Customizing Information Console online help : Customizing icons and the company logo : Changing icons
Changing icons
To change the icons for the controls in the navigation frame and the control bar frame, replace the current image files with different ones. The icon images are located in the <context root>\help\wwhelp\wwhimpl\common\images directory. Replacing these image files changes the icons used for the control bar and navigation frames. Table 11-5 lists and the describes the image files for the icons.
The bookmark method is not available.
Open a single file in the table of contents.
Expand a help topic or sub-topic in the Table of Contents.
Collapse a help topic in the Table of Contents.
There is no previous page available.
Printing is not available for this page.
The related topics method is not available.
Synchronize the frames so that the control frame matches the content frame.
Synchronizing frames is not available.
