Information Console custom tags
Information Console uses Jakarta Struts custom tags and Actuate custom tags. Actuate recommends that customized Information Console web applications use Jakarta Struts custom tags and only the Actuate custom tags shown in Table 8-2.
Table 8-2 Actuate Information Console custom tags Specifies the page to display when the user or URL selects the associated tab Specifies the label on a page’s tab and its key Specifies any HTML or JSP code to apply before defining any tabs Specifies any HTML or JSP code to apply after defining all tabs Specifies any HTML or JSP code to apply to each unselected tab Specifies any HTML or JSP code to apply to the selected tab Specifies any HTML or JSP code to apply between each adjacent pair of tabs Wraps org.apache.taglibs.i18n.
BundleTag Allows the usage of a resource bundle to internationalize content Displays a page or other subset of an Actuate eReport as a Reportlet Specifies the component identifier for SmartSearch Specifies a list of component identifiers for SmartSearch Specifies the component list identified by the name attribute Fetches the formats supported by view server Gets the report’s table of contents data from the Actuate BIRT iServer
