componentList
Provides an array of components on which to search. This tag is used for specifying the component list that is identified by the name attribute. It holds an array of components.
Library
Tag class
com.actuate.reportcast.tags.viewer.ComponentListTag
Attributes
Table 8-8 describes the attribute for componentList.
Table 8-8 Attribute for componentListUsed in
<context root>\viewer\searchframe.jsp
Example
The following example sets the name of the array of components to SearchByNameList:
