content
Specifies the content of a page beneath a tab. Include HTML or JSP code in the body of the content tag or use the page attribute to include another JSP file as the content.
Library
Tag class
com.actuate.activeportal.tags.tabpanel.Content
Attributes
Table 8-9 describes the attribute for content.
Table 8-9 Attribute for content Specifies a file containing the JSP code to use as the content of the page associated with the current tab.If you do not include a page attribute, any HTML or JSP code in the tag’s body becomes the definition of the page.
Used in
<context root>\private\jobs\selectjobscontent.jsp
<context root>\private\newrequest\newrequestpage.jsp
<context root>\private\options\optionspage.jsp
<context root>\private\query\createpage.jsp
<context root>\private\query\runpage.jsp
Examples
The following example uses the page attribute to specify using the code in saveas.jsp as the Save As tab’s page content.
The following example uses the tag’s body to specify the About tab’s content page as the result of the JSP include directive.
