Actuate Information Console custom tags : copyFileFolder
copyFileFolder
Copies files and folders from one location to another.
Library
filesfolders
Tag class
com.actuate.reportcast.tags.filesfolders.CopyFileFolderTag
Attributes
Table 8-10 lists and describes the attributes for copyFileFolder.
Boolean value. If True, add newName to the targetPath. Default is True.
Unique authentication ID assigned to the user after successful login.
Boolean value. If True, create a new version of the file or folder. Default is True.
Boolean value. If True, only the latest version is to be copied. Default is True.
Current user’s locale, such as en_US, from <Context root>\WEB-INF\localemap.xml.
URL that accesses the BIRT iServer, such as http://Services:8000.
Current user’s time zone from <Context root>\Web-inf
\TimeZone.xml.
