Actuate Information Console custom tags : getTOC
getTOC
Obtains the table of contents for a report from the server. It fetches the data in XML form, which is converted for display in the browser. The report is identified by its ID or name. Either the report ID or name attribute must be set.
Library
viewer
Tag class
com.actuate.reportcast.tags.viewer.GetTOCTag
Attributes
Table 8-16 lists and describes the attributes for getTOC.
Table 8-16  Attributes for getTOC
The unique authentication identifier returned by Actuate BIRT iServer on successful login.
The report’s locale, such as en_US, as in <context root>\Web-inf\localemap.xml.
The URL of the server on which the report resides, such as http://Services:9000.
The report’s time zone as in <context root>\Web-inf\TimeZone.xml.
Used in
<context root>\viewer\viewtoc.jsp
Example
The following example creates the table of contents for the Detail report:
<viewer:getToc name="Details.roi" type="roi" format="XMLDisplay"/>
