iterator
Supports iterating through the contents of lists and retrieving specified parameters. The iterator tag populates its invoking JSP with the contents of the list. Information Console and Management Console JSPs make extensive use of the iterator tag to process lists.
Library
Tag class
com.actuate.reportcast.tags.common.IteratorTag
Attributes
Table 8-17 lists and describes the attributes for iterator.
Table 8-17 Attributes for iterator The unique identifier of the results through which to iterate. The unique identifier to use while retrieving values from this iterator. Fully qualified name representing the type of listed objects through which to iterate.Variables
isLastRow: False while iteration is in progress. True when iteration reaches the last row.
Used in
<context root>\viewer\viewdefault.jsp
Example
The following example iterates through a list of job notices:
<cmn:iterator name="igjn" type="com.actuate.reportcast.dstruct.JobNotice"
