message
Implements a body tag allowing the usage of a resource bundle to internationalize content in a web page. The key attribute is required, and is used to look up content in the resource bundle. The args attribute is optional, and if present, provides items to pass to a MessageFormat. The bundle tag must be used first in order to ensure that the proper bundle is loaded.
Library
Tag class
org.apache.taglibs.i18n.MessageTag
Attributes
Table 8-20 lists and describes the attributes for message.
Used in
<context root>\errors\pagenotfound.jsp
Variables
Table 8-21 describes the variable for message.
Example
The following example displays a plain message using the default (first defined) bundle:
The next example displays a plain message using a specified bundle. In this example the default bundle is bundle1 because it is defined first:
| (c) Copyright Actuate Corporation 2011 |   |
