Actuate Information Console custom tags : tab
tab
Defines the label and key for a tab in a tab panel. URIs specifying the key cause selection of the tab and display of the page associated with the tab.
Library
actabpanel
Tag class
com.actuate.activeportal.tags.tabpanel.Tab
Attributes
Table 8-26 lists and describes the attributes for tab.
Table 8-26  Attributes for tab
Specifies the identification key for this tab. If not set, the default is 0, 1, 2 and so on. Use with the selectedTab attribute of the tabPanel tag.
Used in
<context root>\private\common\errors\error.jsp
<context root>\private\common\sidebar.jsp
<context root>\private\jobs\selectjobscontent.jsp
<context root>\private\newrequest\newrequestpage.jsp
<context root>\private\options\optionspage.jsp
<context root>\private\query\createpage.jsp
<context root>\private\query\runpage.jsp
Example
If subpage is defined in a tabpanel selectedTabParameter attribute, the following tag:
<actabpanel:tab key="_scheduled">
provides the ability to select this tab by using the following URI:
http://<application server>:<port>/iportal/selectjobs.do
?subpage=_scheduled
