tabBegin
Specifies HTML or JSP code to execute before defining the first tab in a tab panel.
Library
Tag class
com.actuate.activeportal.tags.tabpanel.TabBegin
Attributes
There are no attributes for this tag. Place the desired code as the body of the tag.
Used in
<context root>\private\common\errors\error.jsp
<context root>\private\common\sidebar.jsp
<context root>\private\newrequest\newrequestpage.jsp
<context root>\private\options\optionspage.jsp
<context root>\private\query\createpage.jsp
<context root>\private\query\runpage.jsp
Example
The following example specifies the inclusion of several images to create a border with rounded edges before defining the tabs.
