Actuate Information Console custom tags : tabMiddleSelected
tabMiddleSelected
Specifies HTML or JSP code to execute for the currently selected tab.
Library
actabpanel
Tag class
com.actuate.activeportal.tags.tabpanel.TabMiddleSelected
Attributes
There are no attributes for this tag. Place the desired code as the body of the tag.
Used in
<context root>\private\common\errors\error.jsp
<context root>\private\common\sidebar.jsp
<context root>\private\jobs\selectjobscontent.jsp
<context root>\private\newrequest\newrequestpage.jsp
<context root>\private\options\optionspage.jsp
<context root>\private\query\createpage.jsp
<context root>\private\query\runpage.jsp
Example
The following example specifies the color, width, alignment, and other attributes of the selected tab.
<ui:tabMiddleSelected>
  <TD bgcolor="#31659C" width=7>&nbsp;</TD>
  <TD bgcolor="#31659C" class="cellSidebarSelected"
    nowrap="nowrap">
    <A href="<%= request.getContextPath() %>/{2}"
      class="lnkSidebarSelected">{0}</A>
  </TD>
</ui:tabMiddleSelected>
