tabSeparator
Specifies HTML or JSP code to execute between defining each adjacent pair of tabs.
Library
Tag class
com.actuate.activeportal.tags.tabpanel.TabSeparator
Attributes
There are no attributes for this tag. Place the desired code as the body of the tag.
Used in
<context root>\private\common\errors\error.jsp
<context root>\private\common\sidebar.jsp
Example
The following example specifies the inclusion of several images to create a dividing line between the tabs.
