Working with dimensions, measures, and levels
The actuate.xtabanalyzer.Crosstab class represents the cross tab element. Use this cross-tab class when working with Data Analyzer and the XTabAnalyzer viewer. Use the functions in the actuate.xtabanalyzer.Dimension class to add, remove, or modify dimensions. Use the functions in the actuate.xtabanalyzer.Measure class to add, remove, or modify measures. Use the functions in the actuate.xtabanalyzer.Level class to add, remove, or modify levels. These classes contain functions that support the creation and modification of the dimensions, measures, and levels in the cross tab. These functions work with information from a data cube that is created with BIRT Designer Professional.
