Running a file job
All design and executable files, such as BIRT Design files, BIRT Data Object Design files, BIRT Spreadsheet executable files, and e.Report executable files appear in the category Items You Can Run. An Information Console user with appropriate permissions can run a design or executable file job. The output of the job appears as a new document in Documents You Can View or as a temporary, in-memory document for immediate viewing or downloading.
When a job is run, the user decides which result they want:
n
