Running file jobs : Scheduling a file job
Information Console can run an executable, document or design file at a scheduled time to enable the user to:
n
n
n
Save the output report document in a specific format or convert an existing BIRT Report document or BIRT Spreadsheet document file into another format like Adobe PDF or Microsoft Office formats such as Word, Excel, and PowerPoint.
n
n
n
Scheduled file jobs support set priority levels between 1 and 1000. The higher the priority value the higher the priority on the BIRT iServer.
Table 4-2 lists supported file types and conversion options for report output.
File-Name Extension
Acrobat portable document format file
Page range, page style, BIDI processing, text wrapping, font substitution, font embedding, chart DPI, save chart in vector graphic
Comma-separated values file
Table name, column list, export columns data type, locale neutral format, encoding, maximum rows
IBM Advanced Function Printing
Chart DPI, page DPI, Plex mode, support the following images: black and white, grayscale, single color, full color RGB, color CMYK
Page range, text wrapping, enable pivot table, chart DPI, export charts as images, hide grid lines, output to multiple sheets
Microsoft PowerPoint format
Page range, page style, BIDI processing, text wrapping, font substitution, chart DPI
Pipe-separated values file
