Using parameters
A parameter is an element in reports or dashboard gadgets that provides input to the select data used in a file job. Report developers use parameters to request report data from users for processing, formatting, and determine aspects such as:
If an Actuate file has parameters, the user sets the parameter values when running the file job or uses the default parameter values set by the developer. If a report parameter file is available, the user that starts a report and loads the report parameters with predefined values.
