Working with a folder
The My Documents navigation pane displays a view of folders that the user has permission to view. The navigation pane lists folders in a tree diagram. If the tree diagram is not visible, select the Tree View skin in the user options, as described later in this document.
Users with appropriate rights can use a folder as a destination for saving new documents.
Figure 2-29 shows the Categories view of folders in a volume called MyBIRTiServer.
Figure 2-29 Navigating Information Console foldersChoose a folder from the navigation pane or the file and folder pane to open it. File access privileges determine which folders a user can view and open. As a user navigates to a folder, Information Console displays the path. For example, Figure 2-30 shows the path to a folder called BIRT and BIRT Studio Examples, in a volume called MyBIRTiServer.
Figure 2-30 Displaying the folder details and pathContact the Encyclopedia volume administrator to move existing files and folders.
