Managing folders and files : Finding a file : Filtering files and folders
By default, all visible files and folders in the currently selected folder appear to a user. Filtering limits the items that appear in the selected folder. For example, a user can apply filter options to display only the most recent files that include the word Marketing or start with a number.
The following parameters are available to filter files and folders:
n
n
n
n
n
For example, to list documents and folders but not executable files, verify Documents is selected, and deselect Executables.
