Navigating a dashboard
Each dashboard has a tab with a name describing the contents of the dashboard. Users can change the order and the name of each dashboard.
Dashboard settings are in the dashboard’s tab menu, as shown in Figure 3-7.
Figure 3-7 Accessing dashboard settingsSubscribed dashboards have different options than a personal dashboard. Table 3-1 lists dashboard settings for subscribed and personal dashboards.
Duplicate the dashboard as a new dashboard Select column or free form layout for gadgets on the dashboard Manage Data Select one or more BIRT data objects or BIRT data object Stores to be data sources of the dashboard Modify dashboard name, header and footer text, auto refresh rate Print the contents of the active dashboard Query and update data object design, BIRT design and external files in use General sharing options and permissions on the dashboard Show Selections Display and optionally reset any data selectors used on the dashboard
