To generate data object data sources, data sets, and cubes for a BIRT report design, first configure BIRT_HOME to access the Actuate commercial model API Java archive (JAR) files from Actuate iServer. To accomplish this task, generate a DesignConfig object with a custom BIRT_HOME path, as shown in the following code:
Using this design configuration object, create and configure a Design Engine object, open a new session, and generate or open a report design object, as shown in the following code:
To generate data sources, data sets, and cubes, use the datamart methods of an ElementFactory object: newDataMartCube( ) for a new cube, newDataMartDataSet( ) for a data set, and newDataMartSource( ) for a new data source. For example, to instantiate a new data source, use the following code:
Associate a handle for a data object data source with an actual data source from the contents of a data or data design file. For example, to associate a data source handle with a data source from test.datadesign, use the following code:
The resulting output file, output.rptdesign, contains the new data source, retrieved from test.datadesign. This data source appears in Data Sources in Data Explorer and establishes a link to the .datadesign file, test.datadesign. The XML source for output.rptdesign includes markup similar to the following lines:
