To create a data object data set, use the newDataMartDataSet( ) method from ElementFactory. For example, to instantiate a new data set, use the following code:DataMartDataSetHandle dataSet =
factory.newDataMartDataSet("Data Set");Associate the data object data cube with a DataMartDataSourceHandle object and then add the name of a data set from the data or data design file. For example, to access a data set called "SetName", use the following code:
