To create a data object data cube, use the newDataMartDataCube( ) method from ElementFactory. For example, to instantiate a new data cube, use the following code:DataMartDataCubeHandle dataCube =
factory.newDataMartDataCube("Data Cube");Associate the data object data cube with a DataMartDataSourceHandle object and assign a data cube from the data or data design file. For example, to access a data cube called "CubeName", use the following code:
