Task 3: Create the main( ) method to test the codeAdd a main( ) method to run the class.
3 Add the main method body shown in Listing 31-1 to your main( ) method.
Listing 31-1 SessionHandle sessionHandle = engine.newSessionHandle( ULocale.ENGLISH );DataMartDataSourceHandle dataSource = factory.newDataMartDataSource( "Data Source" );dataSource.setAccessType( DesignChoiceConstants.ACCESS_TYPE_TRANSIENT );
To access a data source and its contents, the application must first generate and configure a design engine object.
After creating the engine object, the code instantiates a new session. The SessionHandle object manages the state of all open data and report designs. Use SessionHandle to open, close, and create data designs, and to set global properties, such as the locale and the units of measure for data elements. Create the session handle only once. BIRT supports only a single SessionHandle.
Generate a new design handle using the SessionHandle object. Create a design engine element factory using the DesignHandle object.
Create a new instance of DataMartDataSourceHandle and set the datamart URL to the name of a datamart file, include, which corresponds to the include.datadesign file added to the project. Then, configure the access type and add the data source handle to the design handle object.
Finally, open a file output stream to a report design, test.rptdesign, that uses the data object. Export the data design element to the report design.
4 Add the import statements shown in Listing 31-2 to the beginning of the file.
Listing 31-2 import org.eclipse.birt.report.model.api.elements.DesignChoiceConstants;import com.actuate.birt.report.model.api.DataMartDataSourceHandle;
