A dynamic filter report parameter differs from a regular report parameter in one important aspect. Using a dynamic filter parameter, you can provide report users with a list of operators, which they can use to construct their own filter condition.
Figure 20-1 shows an example definition of a dynamic filter parameter where the display type is a text box. Aside from the Dynamic Filter Condition section, where you specify the column on which to filter and the operators to provide to users, the properties are similar to the properties for a regular report parameter.
Like the regular report parameter, a dynamic filter parameter can also provide the user with a list of values. However, values can be presented in a combo box or list box only.
Figure 20-2 shows an example definition of a dynamic filter parameter that includes a list of values. The display type is set to Combo/List Box.
When you create a dynamic filter parameter, you can require the user to specify a value or you can make the filter optional. It is usually good practice to make the filter optional, so that the user can view a report with all the data. For example, if a report displays inventory data by vendor and you create an optional parameter to filter on vendors, the user can select No Condition to view inventory data for all vendors.
On the other hand, you can require that the user specify a value if displaying all the data results in a very long report. A report that runs into hundreds of pages is not only difficult to read, but the report takes longer to generate.
Users often want to select any number of values for a filter condition. In an inventory report, for example, the user might need to view data for several vendors. To support the selection of multiple values, create a dynamic filter parameter as follows:
