Building a data object entails creating a data object file, then adding data sources, data sets, and cubes to the data object. To add these data items, you can:
1
2 Edit the default file name to specify a new name. The extension must be .datadesign and the file name must not contain the following characters:Use a descriptive name that enables users to determine the contents of the data object. A descriptive name is particularly important if users have access to multiple data objects.
