When a dashboard or a report uses a data object, each time the dashboard is refreshed or the report is run, the data object connects to the underlying data source and retrieves data from it. This operation is typically resource-intensive. For a more efficient data access alternative, cache the data in a data object store, and provide dashboard and report users with access to the data object store.
1 In Navigator, right-click the data object design (.datadesign) file, then choose Generate Data Objects.
2 In Generate Data Objects, type a file name for the data object store. The file name must have a .data extension. Choose OK.BIRT creates a data object store (.data file) that contains the materialized data. The file is saved in the same folder in which the data object design file resides.
