Publishing a data object
To make data objects available to report developers using Actuate BIRT Designer, place the data objects in a shared resource folder, just as you do with other shared resources, such as libraries and style sheets.
To make data objects available to dashboard and BIRT Studio users, you must publish the data objects in an iServer Encyclopedia volume. From the iServer perspective, a data object is a resource, similar to Java classes, image files, or libraries, which are resources for reports published in iServer.
You can publish data object design (.datadesign) files or data object stores (.data). A common strategy is to publish the design files, then schedule those files to be run regularly to generate the data object stores. To manage system resources effectively, iServer volume administrators can make the data object stores generally available to users while limiting access to the data object design files.
How to publish a data object in an iServer volume
1
2
Place the data object in the BIRT resource folder. The location of the resource folder is specified in the Preferences page, which you access by choosing Windows→Preference from the main menu, then choosing Report Design—Resource. The default location is the current project folder.
3
Choose File→Publish to iServer. Select Publish Resources, then select the data object to publish.
For more information about creating an iServer profile, assigning a resource folder in iServer, and publishing items to an iServer volume, see “Deploying BIRT reports to iServer,” later in this book. For information about managing files in iServer, see Managing an Encyclopedia Volume.
Additional Links:
