Because a data object contains predesigned data sets, all you do is select a data set from the data object and the columns from the selected data set.
1 In Data Source Selection, select the data object data source to use. Data Set Type displays Actuate Data Object Data Set.
3 In New Actuate Data Object Data Set, in Available Data Sets, select one of the data sets defined in the data object.
5 Choose Finish to save the data set. Edit Data Set displays the columns in the data set, as shown in Figure 4-3.
Figure 4-3
