To add a cross tab to the report, a cube is required to provide data for the cross tab. You can create a cube, using data from a data set, or you can use a predesigned cube in the data object. The option you choose depends on how familiar you are with creating cubes, whether you want modifications to the original cube to propagate to the cross tab, or whether you need control over the cube data. You cannot edit a cube from a data object.
2 In Select Data Source, select the data source that connects to the data object that contains the cube.Figure 4-4 shows the selection of a cube named Revenue from a data object data source named Revenue Expenses Data Object.
Figure 4-4
