The condition for joining values in two fields is usually based on equality (=), as shown in all the examples so far. Less common are join conditions that use any of the other comparison operators: not equal (<>), greater than (>), less than (<), greater than or equal to (>=), and less than or equal to (<=).
The following example shows the use of joins that are not based on equality. In the example, a Sales data set is joined with a Commissions data set. The joined data set uses a >= join and a < join to look up the commissions to pay to sales managers, based on their sales totals and management levels.
Figure 13-19 shows the Sales and Commissions data sets. In the Commissions data set, each level has four commission rates. For level 1, a commission rate of 25% is paid if a sales total is between 75000 and 100000, 20% is paid if a sales total is between 50000 and 75000, and so on.
