This file specifies the encryption settings. BIRT loads the encryption type, encryption algorithm, and encryption keys from the encryption.properties file to do the encryption. The file contains pre-generated default keys for each of the supported algorithms.Type of algorithm. Specify one of the two values, symmetric encryption or public encryption. The default type is symmetric encryption.The name of the algorithm. You must specify the correct encryption type for each algorithm. For the symmetric encryption type, BIRT supports DES and DESede. For public encryption type, BIRT supports RSA.In cryptography, a block cipher algorithm operates on blocks of fixed length, which are typically 64 or 128 bits. Because messages can be of any length, and because encrypting the same plaintext with the same key always produces the same output, block ciphers support several modes of operation to provide confidentiality for messages of arbitrary length. Table 29-2 shows all supported modes.
Table 29-2 Cipher Block Chaining Mode, as defined in the National Institute of Standards and Technology (NIST) Federal Information Processing Standard (FIPS) PUB 81, “DES Modes of Operation,” U.S. Department of Commerce, Dec 1980 Because a block cipher works on units of a fixed size, but messages come in a variety of lengths, some modes, for example CBC, require that the final block be padded before encryption. Several padding schemes exist. The supported paddings are shown in Table 29-3. All padding settings are applicable to all algorithms.
Table 29-3 Optimal Asymmetric Encryption Padding (OAEP) is a padding scheme that is often used with RSA encryption. The padding scheme described in RSA Laboratories, “PKCS #5: Password-Based Encryption Standard,” version 1.5, November 1993. This encryption padding is the default. The padding scheme defined in the SSL Protocol Version 3.0, November 18, 1996, section 5.2.3.2.Listing 29-1 shows the default contents of encryption.properties.
Listing 29-1 #for RSA algorithm , there is key pair. you should support private-public key pair
