About META-INF/MANIFEST.MF
META-INF/MANIFEST.MF is a text file that is included inside a JAR to specify metadata about the file. Java’s default ClassLoader reads the attributes defined in MANIFEST.MF and appends the specified dependencies to its internal classpath. The encryption plug-in ID is the value of the Bundle-SymbolicName property in the manifest file for the encryption plug-in. You need to change this property when you deploy multiple instances of the default encryption plug-in, as described later in this chapter. Listing 29-2 shows the contents of the default MANIFEST.MF.
Listing 29-2
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: Actuate Default Security Plug-in
Bundle-SymbolicName: com.actuate.birt.model.defaultsecurity;singleton:=true
Bundle-Version: <release><version>
Require-Bundle: org.eclipse.birt.report.model,
org.eclipse.core.runtime
Export-Package: com.actuate.birt.model.defaultsecurity.api
Bundle-ClassPath: acdefaultsecurity.jar
Bundle-Vendor: Actuate Corporation
Eclipse-LazyStart: true
Bundle-Activator: com.actuate.birt.model.defaultsecurity.properties.SecurityPlugin
Additional Links:
