You need to implement these methods and program your encryption and decryption logic there.To install the custom encryption plug-in, copy the plug-in to the product’s plugins folder, where the default plug-in resides. Change the isDefault property in plugin.xml to true. Change the isDefault properties of the rest of the encryption plug-ins to false.
