1 In Data Source Selection, select the ActuateOne for e.Reports data source to use. Data Set Type displays ActuateOne for e.Reports Data Set.
4
Figure 7-3
5 In Select Columns, choose Refresh Columns. Available Columns displays the column names from the ROI file, as shown in Figure 7-4.
Figure 7-4
6 Select the columns to include in the report. Choose the right arrow to move the columns to the Selected Columns pane, as shown in Figure 7-5.
Figure 7-5
7 In Edit Data Set, select Preview Results. Figure 7-6 shows the data rows returned by the data set.
Figure 7-6 If the error message shown in Figure 7-7 appears, you selected columns from different sections in the e.report.
Figure 7-7 Error message displayed when the selected columns are from different sectionsIf the error message shown in Figure 7-8 appears, you selected columns from both data and page controls.
Figure 7-8 Error message displayed when selected columns are from data and page controls
Figure 7-9 Note each name’s prefix. In the example shown in Figure 7-9, the first three columns are in the SalesRepTitleFrame component, and the fourth is in the Page component. This information indicates that the first three columns are from data controls, and the fourth column is from a page control.
