The date or date expression that represents the start date. If a start date does not have a time value, the function assumes the time is midnight, 12:00 AM.The number of hours to add to the start date. If you specify a negative number, the result is as if the number is subtracted from the start date.The date-and-time value that results from adding the specified number of hours to the start date.
