The number of quarters to add to the start date. If you specify a negative number, the result is the number subtracted from the start date.The date value that results from adding the specified number of quarters to the start date. A quarter is equal to three months. For example, if you add two quarters to 9/22/08, ADD_QUARTER( ) returns 3/22/09.The following example adds two quarters to each date value in the ForecastClosing field:
