EasyScript is an expression syntax similar to the syntax used in Excel formulas. Like Excel, EasyScript provides functions for performing calculations on report data. In Actuate BIRT Designer, EasyScript is supported in most places an expression is required. For example, when specifying an expression for a computed column, a column binding, a filter condition, or a map rule, you can use either JavaScript or EasyScript.
