If you consistently use EasyScript or use it more than JavaScript, you can change the Default Syntax property in Preferences to EasyScript syntax. To access this property, select Window
→Preferences, and choose Report Design—Expression Syntax. After changing the default syntax, the EasyScript syntax icon appears by default every time you create a new expression.
The Default Syntax property does not convert existing JavaScript expressions to EasyScript expressions, and vice versa. To change the syntax of an expression, you must select the syntax type and edit the expression accordingly.
