FIND( )The numerical position of the substring in the string. The first character of a string starts at 1. If the substring is not found, FIND( ) returns 0.If the product name is 1969 Ford Falcon, FIND( ) returns 6.The following example searches for the first hyphen (-) in each product code:FIND("-", [ProductCode])If the product code is ModelA-1234-567, FIND( ) returns 7.The following example uses FIND( ) in conjunction with the LEFT( ) function to display the characters that precede the hyphen in a product code. The LEFT( ) function extracts a substring of a specified length, starting from the first character. In this example, the length of the substring to display is equal to the numerical position of the hyphen character.LEFT([ProductCode], FIND("-", [ProductCode]))If the product code is ModelA-1234, the expression returns the following string:
