NOT( )The following example uses NOT( ) in conjunction with the IF( ) function. It tests if the value in the State field is not CA. If the value is not CA, it returns the value in the Markup field multiplied by 10%, and by 15% if it is.IF(NOT([State]="CA"),[Markup]*10%,[Markup]*15%)The previous IF( ) expression is semantically equivalent to the following expression:IF([State]="CA",[Markup]*15%,[Markup]*10%)
