ROUNDDOWN( )
Rounds a number down to a specified number of digits.
Syntax
ROUNDDOWN(number)
ROUNDDOWN(number, dec)
Arguments
number
The number to round down.
dec
The number of digits to round number down to. If you omit dec, ROUND( ) assumes 0.
Returns
A number rounded down to a specified number of digits.
Example
The following example rounds down the numbers in the PriceEstimate field to return an integer. For example, if the PriceEstimate value is 1545.25, ROUNDDOWN( ) returns 1545. If the PriceEstimate value is 1545.90, ROUNDDOWN( ) returns 1545.
ROUNDDOWN([PriceEstimate])
The following example rounds down the numbers in the PriceEstimate field to one decimal place. For example, if the PriceEstimate value is 1545.56, ROUNDDOWN( ) returns 1545.5. If the PriceEstimate value is 1545.23, ROUNDDOWN( ) returns 1545.2.
ROUNDDOWN([PriceEstimate], 1)
The following example rounds the numbers in the PriceEstimate field down to one digit to the left of the decimal point. For example, if the PriceEstimate value is 1545.56, ROUNDDOWN( ) returns 1540. If the PriceEstimate value is 1338.50, ROUNDDOWN( ) returns 1330.
ROUNDDOWN([PriceEstimate], -1)
Additional Links:
