When specifying an expression, the JavaScript syntax is the default. Figure 19-1 shows the icon that represents JavaScript syntax. Clicking on this icon opens the JavaScript expression builder.
      Like the JavaScript expression builder, the EasyScript expression builder provides help selecting functions and fields to use in an expression. To use a function in an expression, type the first letter of the function, then select a function from the list that appears. To use a field, type the left square bracket ([), then select a field from the list.
