Using the animation effect, you can animate different parts of a chart or gadget, including the background, title, data plot, data values,
x-axis labels,
y-axis labels, and more. After selecting the object to animate, you set properties to define how the object moves, including the direction, pattern, and duration of the animation.
For example, you can animate the data plot of a column chart so that the columns are drawn from the left side of the chart to the right side in five seconds, with a bouncing motion at the end.
Figure 17-29 shows the properties set to create this type of animation. The Attribute to Animate value of X coordinate specifies that the
x (horizontal) position of the plot is animated. The Start Value setting of Chart Start X specifies that the animation starts from the left side of the chart.
Table 17-16 describes the animation properties.
Table 17-17 describes the attributes of a chart part, or object, that you can animate.
Table 17-18 describes the macros that you can select for the Start Value property described in
Table 17-16. Chart refers to the entire area of the Flash chart or gadget. Canvas refers to the plot area.
The start x position of the chart, which is equal to 0
The start y position of the chart, which is equal to 0
The end x position of the chart, which is the same as the chart width
The end y position of the chart, which is the same as the chart height
The center x position of the chart
The center y position of the chart
The start x position of the canvas, which is the x coordinate of the left side of the canvas
The start y position of the canvas, which is the y coordinate of the top of the canvas
The canvas end x position, which is the x coordinate of the right side of the canvas
The canvas end y position, which is the y coordinate of the bottom of the canvas
The center x position of the canvas
The center y position of the canvas
Table 17-19 describes the type of animation that you can select for the Type property described in
Table 17-16.
