Task 3: In this procedure, build a data set to indicate what data to retrieve from the OrderDetails and Products table.
Data Set Type specifies that the data set uses a SQL SELECT query to retrieve the data.
4 In New Data Set—Query, type the following SQL SELECT statement to indicate what data to retrieve:
5 Choose Finish to save the data set. Edit Data Set displays the columns specified in the query, and provides options for editing the data set.
6 Choose Preview Results. Figure 17-34 shows the data rows that the data set returns.
Figure 17-34
