Task 5: On this page, under Select Data, Use Data From is selected by default and its value is set to SalesTotals, the data set you created earlier. Data Preview shows the columns and values returned by the data set.
2 In Data Preview, select the PRODUCTLINE column header and drag it to the empty field to the right of Category (X) Series, as shown in Figure 17-36.
3 Select the TOTALPRICE column header and drag it to the empty field in Value (Y) Series, as shown in Figure 17-36.
2 In the layout editor, enlarge the Flash chart. Increase its width to seven inches, and increase its height to three inches.
3 The Flash chart is animated. Columns are drawn linearly from the bottom to the top. Figure 17-37 shows the generated chart.
Figure 17-37
