Task 6: Animate the x-axis labelsIn this procedure, animate x-axis labels to draw them linearly from left to right.
3 Choose X-Axis in Chart Area, shown in Figure 17-38. Then, choose Effects.
Figure 17-38 Select X-Axis and Effects to apply animation to x-axis labelsIn Effects, Chart Parts displays X-Axis Labels, indicating that is the part of the chart selected for an effect.In Effects, shown in Figure 17-40, My List shows Animate Horizontally, the effect you just created. The check mark indicates that the effect applies toX-Axis Labels. A symbol under Animation indicates that the effect uses animation.
Figure 17-40
