Task 2: On this page, under Select Data, Use Data From is selected by default and its value is set to SalesTotals, the data set you created earlier. Data Preview shows the columns and values returned by the data set.
2 In Data Preview, select the TOTALPRICE column header and drag it to the empty field in Value Definition, as shown in Figure 17-43.
Figure 17-43 The gauge in Preview changes to use the specified data. The needle shows a value of 3.85M, which is the total for Classic Cars, the value in the first row returned by the data set.
2 In the layout editor, resize the gauge. Increase its width to 7 inches, and decrease its height to 1.5 inches.
3 Choose Run→View Report→In Web Viewer. The gauge is animated. The gauge is drawn linearly from the left to the right, and the needle moves from the left edge of the gauge to its final position.
