Task 5: In this procedure, animate the region labels to move from the left of the gauge to their final positions.
2 In Properties, Choose Effects, next to the Label property value. In Effects, Effect Target displays Gauge Labels, indicating that is the part of the gadget selected for an effect.In Effects, shown in Figure 17-49, My List shows Animate Horizontally, the effect you just created. The check mark indicates that the effect applies to Gauge Labels. A symbol under Animation indicates that the effect uses animation.
Figure 17-49
