A single Flash chart or gadget can use any number of effects. The Effects dialog box, shown in Figure 17-28, shows all the effects created for a chart or gadget. In this dialog box, aside from creating a new effect as described previously, you can perform the following tasks:
See which parts of the chart or gadget have effects applied. Open the drop-down list next to Chart Part or Effect Target. Items that have effects applied appear in bold.
See which parts of the chart or gadget a particular effect applies to. Under My List, hover the mouse pointer over an effect. A tooltip displays the name of the chart or gadget part that uses the effect. For example, the following tooltip indicates that an effect applies to a chart’s y-axis labels and title:
