Needle base or pivot properties define the appearance of a needle base, or pivot. Drawn as a circle, the base is the point around which the needle rotates. A needle base appears only for a meter gauge. Figure 17-8 shows the needle base properties set for a meter gauge. The size of the needle base is larger than the default size, and the fill color is set to a radial gradient.Table 17-4 shows all the needle base or pivot properties. These properties are used only in a meter gauge.
Table 17-4
